power
danz1r
know i know that a bravada is no typhoon but its all i got and it is bassed on one. so how much can a stock chassi and drive train take power wise before it is too much?
mattw
Re: power
Your tranny is your weak link.. Even well built a 700R4/60E can only take ~500HP MAX.
gkrcr882
SyTyless......for now!
Re: power
Stock transmission and front driveshaft. The high torque output causes both to break under heavy load (launching). Depending on what year you have, there were different variations of the 4.3 in the Bravada, none of which were anything spectacular. Power can be made, but the tried and true method is V8. Trans, t-case, everything from the bellhousing back stays exactly in place. Rear axle seems to not be much of an issue unless you're running some low 1/4 mile times and big power. Chassis twists while staging the truck anyways, so it isn't anything to worry about. Coilovers, solid motor mounts/engine tiedown and coils in the back or trac bars seem to take care of things.
danz1r
Re: power
im building a 375 hp 350 with a 100-150 sniper shot 4l60e trans wwith the factory 3.73 gear the truck is a 93 olds bravada( real gem...lol)
