PP2 files
kwick6
I got a bad disk from Xtronics when my PP2 arrived.
If anyone has the files, can you help me out?
I have XP.
The install instructions that came with it say....
*******Windows NT/2K/XP***********
If you want to run on a NT, 2K, or XP machine, you must read the
Read_Me.Txt file about updating the registry before using.
If that file is on the disk, and when I put the disk in it says not formatted, well...
Thanks,
Scott
kwick6
Ok. Software is installed.
Can someone tell me how to boot up in DOS?
I read that if your doing flash chips its better, because
windows can slow it down.
Thanks,
Scott
GM TURBO
Sell Out
With 95,98,2K (dunno about XP) - hit the F8 key while the "splash" screen appears. The splash screen is the pretty logo that comes up after POST - before the OS (operating system) loads. It will give you a menu - one should be start in DOS - or some crazy shit like that.
kwick6
I see that there is a folder called DOS Files 3.70, within that folder there is a file called D250X.
When I double click the D250X, a window opens that looks like DOS, is that it? It says at the bottom "hit space bar to continue"
I got this as I was typing the above, I'll try that thanks Dave.
I'd still like to know about the above, and if that is a way to go into DOS as well. I suppose that clicking on the D250X file is like a shortcut to the programmer in DOS.
Scott
kwick6
Well, I tried hitting the F8 on startup, but that didn't do it. I'm using XP.
I am trying to double my 16k bin. I wonder if I could just burn the first 16k on the chip, then set the buffer start to 04000 to burn the second half of the chip.
I'd like to learn how to double the bin in DOS though, and save the new bin which would be 32k, then just burn that to the chip.
thanks,
Scott
kwick6
I tried several times to get this to work. Everytime I enter this ...
copy xxx.bin+xxx.bin yyy.bin
it just says "the system cannot find the file specified"
I have tried it with a couple of different bin files that I have
on the computer, but it just doesn't work.
To get to DOS, correct me if this is wrong, I went to
Start, programs, accessories, command prompt C:\
When I click the command prompt, a window opens, and the line reads
C:\Documents and Settings\Scott>
then I would enter that line copy xxx.bin+xxx.bin yyy.bin
Oh well, no biggie, I'll get it someday.
I don't really need it right now, as the PP2 will put the 16k file into the last 32 anyway.
Scott
kwick6
I did something right, but its still not right.
I did this... C:\Documents and Settings\Scott> CD my documents
then it said ... C:\Documents and Settings\Scott\My Documents>
and I did the ... copy xxx.bin+xxx.bin yyy.bin
and it seemed to work, went and looked at it in my documents, and it was there, but it was only 1KB, when the xxx.bin is 16KB.
I opened yyy.bin in hex workshop and it isn't complete, just a few lines, opened the xxx.bin and its all there.
what gives. I thought I finally had it. :evil:
Scott
Tooky
Serious about performance
Any Windows NT-based OS such as Windows NT 4.0, Windows 2000, or Windows XP, will not have the ability to boot to DOS because they are completely self-contained; they do not boot on top of DOS like Windows 9x does (including Windows Me). NT4/2000/XP has a "Command Prompt" window which is like a DOS prompt but it's really emulating 16 bit and not true real-mode DOS where the CPU is put into "Real Mode" which is where the benefit of chip-flashing in a more stable environment would be realized.
The solution is to get a floppy boot disk from a Windows 9x computer or any other boot disk that runs DOS and stick that in your floppy and reboot the computer (assuming your PC is set to boot from floppy drive, as most are.)
