Pre-startup checklist after rebuild
bender
Im just about done putting this thing back together. I got the core support and inner fenders on tonight, only thing left is front sheet metal. I am filling and topping off all fluids, I drained all the old gas out. I am going to put a new fuel filter in before I fire it up. All new ignition stuff, engine is primed and should be ready to go soon.
I am looking for anything i maybe should do prior to trying to fire for the first time. I should have it ready to start on friday. It is an all stock truck with a new engine. Thanks for the input.
Aeroking
e.i.
Re: Pre-startup checklist after rebuild
Turn the key to on, dont start, the fuel pump will run, let it pressurize the fuel system. Then turn it off, and check the lines for leaks
prime the oil system with a primer shaft, run it for 5 minutes with the break-in oil, then change oil and filter, and check for shavings.
Hookup your scantool while its running, and check for any sensors not responding.
While its running, with the tan wire disconnected, set the static timing to 0.
Listen around the intake, plenum, and throttle body seams for air leaks.
Touch the upper an lower rad hoses to verify that the thermostat is letting coolant into the engine
bender
Cool, Thanks.
I installed new o-rings on the injectors and fuel rail. Hopefully they all seated right. I need to get a cable for my laptop so I can use datamaster. Maybe I can rent a scan tool from one of the parts stores for now.
:2cents:INHO I'd prime the fuel system with the connector by the dist. You will immediately see any leaks ('cux you're in the engine compartment) and you can hear the pressure come up and the air go out. You can run it with the rad cap off because as soon as the t-stat opens you'll need to add some coolant anyway. CEL will tell you if you've got a code. Be prepared for the timing to be way off. We've all done it. Cannot overstress the importance of priming the oil system. If it reves way beyond a normal idle shut 'er down and look a missed vac connection. Just my additional Maybe have a fire extinguisher at the ready? JIK :2cents:
bender
i primed the engine a good 15 min so i shouldbe safe there. does that fuel pump connector just got to 12v? i also put on a new silicone vac tube kit so that should be good too.
WyoSyclone
Don W.;744961If it reves way beyond a normal idle shut 'er down and look a missed vac connection. :[/QUOTE said:
With the battery being disco'd for so long the ECM will probably go into learn mode, which may make it idle up around 1600 for as long as 2 minutes... please slap me if I'm remembering this incorrectly... ;)
Yes on the connector, goes to 12v. You'll see it as a single female push connector on the firewall by the dist.
Don't know the exact RPM learn mode is. But if it goes way up, like 2500 you have a leak. Ask me how I know...:rotf:
