precautions after engine overheat
cvcsmkr
did the pte44 install, capped coolant return line(on top of block?).
noticed turck running sluggish, pulled over and smoke everywhere, found the coolant cap had popped off. the temps got to halfway up stock temp gauge.
i am going to change oil and flush radiator.
and run dm on it.
anything else???
chad
jwaller
Evil Genius/SyTy Guru
Re: precautions after engine overheat
did you also cap the coolant port on the bottom of the block?
cvcsmkr
yes i did.
only the top one popped off.
Well if doesnt start pumping oil and/or making funny noises consider yourself lucky and run the thing.
