Predator tuning or "Flash" tuning for Typhoon?
Scot
Just wanted to see if there was some way to "flash" the typhoon instead of adding a chip? With my Evo i had it flashed which they played with the timing and the a/f ratio to get a decent amount of power. is that available for the typhoon?
thanks
smeagol
Re: Predator tuning or "Flash" tuning for Typhoon?
thanks
Newer cars had their programs/calibrations in flash based storage. Older cars had their info stored in ROM or EPROM. Basically had no way to write or re-write data to those chips. Had to physically swap 'em, remove & replace, and so forth.
So no, there's nothing simple like that available for the Syty. There are new advances that allow for some calibration work on the fly, but nothing that is comparable to the PCM flash modules.
Scot
thanks guys. I was just looking for a quick easy way to pick up some power. My truck had previously been chipped, but it isn't right now.
Anyone know somewhere near harrisburg, pa to do a good job tuning with a chip? i would assume it has to be on a dyno or a road tune?
Drive down to see Phil Long and he can dyno tune it for you and give you a 16 level chip to go with it.
Scot
where is Phil Long?
thanks
