pro-gram main cap info needed
i was looking to get a set of these splayed but unsure which ones you guys are using on these motors are you just buying the v8 kits and using the kit less on cap?
also do i get it stepped i see different types on websites on this link which one would i use or is there a kit just for the 4.3 v6.
i know i need them splayed just unsure about the rest of the info.
any help would be greatly appresciated.
thanks
SB350C12 Chevrolet null > Main Caps > Pro-Gram Engineering > Small Block Billet > 350 > null
Small block 350 stepped caps with angle bolts for 2 bolt block with stock register $248.74
SB350C12F Chevrolet null > Main Caps > Pro-Gram Engineering > Small Block Billet > 350 > null
Small block Chevy 350 flat bottom caps with angle bolts for blocks where stock dipstick usage is required. $248.74
SB350C22 Chevrolet null > Main Caps > Pro-Gram Engineering > Small Block Billet > 350 > null
Small Block 350 Chevy Splayed Center Caps with 2-Bolt Register and 22 Degree Outer Bolts $248.74
SB350CFA Chevrolet null > Main Caps > Pro-Gram Engineering > Small Block Billet > 350 > null
CHEVY 350 FLAT-BOTTOM SPLAYED CENTERS (3 CAPS) $248.74
SB350CFS4 Chevrolet null > Main Caps > Pro-Gram Engineering > Small Block Billet > 350 > null
CHEVY 350 FOUR BOLT REPLACEMENT CENTERS (3 CAPS) $248.74
