prob. after 160 t-stat
TYGUY
i changed a few things but i think my problem is the 160 deg. t-stat. i did a complete tune up. Plugs, wires, cap, rotor, intercooler pump, hoses, and an adjustable FPR. I set it at 43 witch I read was pretty close to stock.
Problem: lots of spark retard, at some points 10.xx via Data Master, and at low boost and RPM levels. i added some octane booster (TORCO). it helped a ton now its at max 3.xx. But it did this before without the TORCO. i also got a rich code. ?? this is why I thought t-stat.
So I thought it was NOT going closed loop. Well I checked and it IS going into closed loop. But engine temps only reached 158 max. and that was after driving for a while. It was 34 deg out yesterday. I also see that at one time injector duty cycle was at 109.6…..? I need to find the time I guess to put the 50# injectors and the chip in. but will this make the spark retard problem worse? Sorry for the long post and sorry if this doesn’t make sense (I write how I talk). Any help would be very much appreciated.
Dustin
Merk
Re: prob. after 160 t-stat
change back to the 195 and re-evaluate.
Post your results
TYTILIDIE
METH HEAD
I dont care what anyone says, a 160* does no harm. Ive benn runnning one for about a year now and have had 0 issues. Are you sure you didnt screw up your plugs wires cap or rotor? Did you check your timing afterwards? What wires are you using? Wgat plugs at what gap?
TYGUY
have not checked the timing... i should be able to tomorrow. plugs are NGK stock replacement numbers. gap @ stock also. (read it off the sticker under the hood). i have am MSD 6AL. should i widen the gap? how should i set the FPR? what about cold weather, could that give spark retard? i know on my lightning it ran like dookie when it was to cold out.
Dustin
KETCH-UP
I second the notion of going back to the 195. My TY stumbles and runs crappy with a 160 in it, and I went back and forth 2 times with 2 different thermostats. Ended up with a 180 for year round. I dont know why most trucks are happy with 160, and some are not?
The few times I drove my truck this winter it sucked ass. The heater got cold when driving after it warmed up in the drive way and the damn t-stat gauge moves like 1/8th of an inch. Previous owner said it was a 160deg.
TYGUY
going by "feel" the truck has never ran better. but hool up DM and you see somthing is wrong.
MasterBlaster. how does your truck do in the summer?
Dustin
Dustin
It doesn't run hot but thats strictly going off of the gauge. I wish I had a laptop and DM to get at this thing but thats not on the agenda any time soon. I just dont do too many open throttle blasts since its my only form of transportation right now. :(
TYGUY
QUICK STORM said:
did you check your o2 sensor, what is your fuel trim at?
L term Percent is -2.3 the O2 is @ low 900's (903-918) at the same point...
when in boost
i think it was bad gas or the cold weather... My TY seems to run different every day.
i am putting in the chip and 50's when i get back from this next business trip. and add an MSD distib, and a wide band see if i cant get it figured out.
Dustin
QUICK STORM
B.A.M.F. BMW Tech
yes, this means that the vehcile is running rich and the computer is compensating by pulling fuel. change the o2 sensor and pull your ecm a and b fuses to reset the short term/long term fuel trim
TYGUY
i changed my FPR also.... is the FP set correct ar 43? i will pick up an O2 tomorrow, thanks
TYGUY
its adustable.... who sales the m500 WB02? since i need a new O2.
TYGUY
the PLX m-500 sims the stock narrow band, and adds the wide band feature too.
