Hi all,
Well, the stock fuel pump on my truck died and I bought a walbro from Ron Gregory(Thanx man!) I finished the install and the truck started like it was brand new
. I have a fuel pressure gauge installed on the fuel rail. I went to see what fuel pressure the gauge was getting and it showed 80psi
(with the stock the reading was 20psi) So I did what everyone says I should do to set the stock fuel pressure. I poped out the fuel pressure regulator's vac. line and put it back again. I went to see the reading and it was showing 42.5 PSI
, but it only lasted for a couple of seconds then the gauge went again to 80 PSI :x. The truck at idle is fine, but as soon as you give it throttle it feels like shit.
I did the same about 3 times with the same results. Any help will be greatly appreciated.
Thanx
Thanx
