Problem tuning
Trapper
I finnally got a hard drive to work and down loaded a bin close to what I have. Now I have Tuner pro RT in but I can't log because I don't have a log file to start with? And can anyone help me with my Datamaster I'm trying to put it on my lap top too.
sy#2921
BAMF
Re: Problem tuning
with tunerpro when you go in and select a log file you actually need to create it. So right click in the box and create one then you will be good to go
Trapper
Re: Problem tuning
Bruce I got an unknown file format warning. I have the data crack but I forgot what order to install to make it work. SO I right click the selet a file and create a file in there?
Syclone#2960
What ever it takes!!
Re: Problem tuning
S:oops:rry bro I sux at computer stuff.
Re: Problem tuning
Yep, when it says to select a file, you can also create a new file. This file then will hold all the logs as sessions (until you create another file).
I will usually create a new log file each time I tune, go to track etc. You COULD do 1 file for your truck and have 100 sessions or whatever. File will get big and hard to email to others though.
Tunerpro is really simple once you get the hang of it.
sy#2921
BAMF
Re: Problem tuning
You need to create a new file after 10-15 sessions. It will let you physically to record but will not save any more data after a certain point. Ask me how I know this wont work
Trapper
Re: Problem tuning
Ok I think I got it. Now I got a file. I need to find where I put autotune. And what to do with this file when I find it. I pasted from tuner pro the required ve's why is the sugested ve's the same #.
Trapper
Re: Problem tuning
I got the file session swaped over to a CSV file now I cut and paste the right VE number where it's supose to go. I don't know if I can fumble my way through this.
Re: Problem tuning
I think there is a video posted on tuneyfish, might help you.
Instructions are also in autotune step by step.
Trapper
Re: Problem tuning
Ok found the instructions, maybe I can fumble through this. If I can any idiot can.
Trapper
Re: Problem tuning
Well I think I got it but I'm running into a few problems my hard drive dosen't boot well and I have the wrong power cord and it makes it mess up a little. Sometime it dosen't mind being transfered from the house to the truck and then sometimes it just goes blank and I have to start all over again, but I downloaded what I think I changed around with Autotune, and as soon as I did it shut the truck off? It started back up, but It didn't like it ran rougher than the base code fro Dig. I downloaded another moddified bin from $59 and it seemed to like it. Adjusted 29f a bit to get it close to where I like the AFR. But I will datalog this today when I go out.
Re: Problem tuning
FAST, BS3, Stock they all need tuned. Some easier to figure out maybe but the same theory and techniques apply to all.
AJ just has identity issue driving around in his wife's teal typhoon.
