Problems after Ultimate V9 Install...
Dr.Evil
Addicted to Boost
today I got around to installing the V9 Ultimate that came with the truck. I hooked everything up including the 3 Bar MAP and fired it up. It poofed a bit more smoke than ususal, but seemed to run fine. I set it to T115 and took it for a spin. I gave it a little gas and it stumbled, sputtered and fell on its face.
I tried putting the 2Bar sensor back on and it didn't idle at all. I took that off and and fired it up. It acted just like it did with the 3Bar hooked up. I have a feeling the 3bar is broken.
We took resistance readings of the 3bar and got the following:
A B C
A - 9.3K 3.8K
B - - 5.4K
C - - -
Are these numbers okay? I'm hopeing that the sensor is bad and not someone else. Could someone verify these #'s for me?
Also, does the ultimate require a high-flow fuel pump and FPR? I have these but havent installed them yet. I just wanted to get the chip up and running.
Any help would be great.
smeagol
Re: Problems after Ultimate V9 Install...
The Ultimate setup was calibrated with 50psi base fuel pressure, so that would cause some problems. Fuel pump required...yes and no. No, it's not required for you to actually run/drive the truck. Is it a good idea for WOT performance and safety? *Definitely*
Also, the first question to ask in any Ultimate related problems - did you piggyback the stock chip properly?
odium
1BADGMC
Would you happen to know what it means if the knock LED stays coninstently on? The truck is driving fine, but the knock LED doesn't go out when a knock occurs such as a hammer on the back of the intake. Datamaster shows it, but the LED just stays on.
Dr.Evil
Addicted to Boost
How is the stock chip used? Does it plug into the prongs on the ultimate? I was wondering what those were for and didn't see any mention of it in the instructions. So the stock chip plugs into the ultimate and the ultimate plugs into the stock chip socket?
Dr.Evil
Addicted to Boost
I just realized that mine is constantly on also...can anyone answer this Q?
odium
1BADGMC
I emailed the chip manufacturers and hopefully I'll get a response within the next week. The chip works perfectly (cycles PROM ids, shows changing mV, etc.) other than this one problem.
The stock chip plugs into the ultimate with both chips being on the same side of eachother. The ultimate then gets inserted in to the ECM. The truck wouldn't run if it weren't installed correctly.
odium
1BADGMC
I have the same problem as Dr.Evil and my 3bar has never been ohmed. The chip runs great, but the knock LED stays lit.
Dr.Evil
Addicted to Boost
kreepinty said:
you could have hurt the sensor by ohming it.
how so? Are they that sensitive?
I will plug in the stock chip and hopefully that will fix everything. I tried a few places around town and no one can locate a 3bar sensor.
Dr.Evil
Addicted to Boost
EDIT
nevermind I figured it out.
