Problems w Gen 7+, Ultimate OK ?
Lynn D. Brown
Hey Guys, I guess nobody has gotten the Ultimate to work with 76 # injectors yet, huh ?
I am trying to get my Gen VII+ ECM tuned up, but am having no luck so far, so was looking to use the stock ECM w upgraded chip as a backup. Having lots of problems and hardly know where to start.
Anybody ?
smeagol
The ultimate hardware will work with any calibrations you want to use. The problem is that no one has *generic* 75# injector calibrations, and I have never tuned them on any syty with a stock computer. If you want to do custom calibration work with Nolan etc, you can still use the Ultimate hardware to do that sort of work.
ed hess
race or get outta the way
Re: Problems w Gen 7+, Ultimate OK ?
Anybody ?
dont know if you want to do this.... but fly harry to you!
are the issues with tuning the gen7 or elsewhere?
sure you know you will go faster with the gen7!
ed
Lynn D. Brown
Gen VII Problems
Gen VII Problems
The problems that I was having w the Gen 7 were as follows :
1.) Terrible Cold Start n- Had to pump like hell for ~ 30 sec.
2.) Idle - OK when cold, but wouldn't stay after warm up. Had to keep foot on accel.
3.) Transition from cruise to acceleration - kicked and sputtered and backfired. Would usually take off like hell once I got past that.
4.) Kept driving around, adjusting A/F in different areas to see if I could get rid of the kicking and backfiring. No luck.
Now I seem to have a battery drain problem, and my fuel pressure has gone south, altho' the pump spins when I put 12 V on it from the prime connection. Maybe I need a new Walbro. I have so many problems, I hardly know where to start.
warmpancakes
1,2,3 are all due to your program oh and you dont adjust the a/f you adjust the fuel and timing map to achiev your targer air fuel.
Lynn D. Brown
Adjusting Fuel w Gen VII+
So, U can't just adjust the A/F directly ? Doesn't that not take ? Will it only change when the fuel itself is changed ? I have no feel for fuel rate #'s. Think I was out of gas as far as the FP problem. Guess I'll start tracking the amp drain w an ampmeter.
