Problems with Gauge Pod Ultimate
HighPerformanceTrucks
Lift & Shift Specialist
Anyone have any problems with their boost and timing settings changing to T3-24 by itself? I've had this happen 4 times already. Today I had the display locked out on t120 when I left my house and I noticed at the stop light down the street it was at T324!
I also seem to have a problem where the motor dies momentarily and the check engine light illuminates. I think there is something wrong with the EPROM as my ignition system is tip top. It only does this on the T3 timing settings.
jwaller
Evil Genius/SyTy Guru
I had my normal ultimate do this. todd fixed it.
michael had his normal ultimate do this and I believe todd fixed it as well. I think it was the button for swithing programs was shorting out. dunno but todd fixed ours and I'm sure he'll help you too.
BillC
Also, check the routing of the wires/ribbon cable. Induced noise can cause the Ultimate hardware to switch programs (voice of experience, BTDT). Re-routing the ribbon cable away from any noisy or high-power components or switches should help.
