Proper radiator name...
J_SULLIVAN
A&P slave monkey
What is the Proper name for the radiator underneath the engine??? There looks like there should be a plug on the lower left corner of it. It has leaked all the coolent and turbo performance sucks! 0X When I pour coolant into the I/C pump it leaks right onto the ground...
DanenGraham
Big in the rear
it is the lower heat exchanger. it has a petcock just like a normal rad, u might need one to fix the leak. :roll:
InvisiBill
the Sandman said:
CCHE (Charge Cooler Heat Exchanger)
"Coolant" actually. =Þ
The upper part of the IC is the Charge Air Cooler. The incoming air passes through a radiator inside it, where the air is cooled by the coolant. The coolant is pumped down to the Charge Coolant Heat Exchanger where the coolant is cooled by passing airflow (in theory at least).
J_SULLIVAN
A&P slave monkey
OK... Need a new one! Where would I get one and would you guys go with an aftermarket lower heat exchanger??? Also noticed that "BDUBB" has somekind of hose running from where I am missing my petcock. What is that??? 0X
bdubb
I am teh kingpin!
i do?
J_SULLIVAN
A&P slave monkey
I was referring to this pic on BDUBB's site... -Gallery- - Maybe Dubb ownz YOU - Pic 15 of 16 on the first page... What is that coming from the bottom of the bumper??? 0X
