Pros/Cons To Using Double Gaskets For Vortecs
tbauer03
TRBOBOX
Ok sorry the search feature sucks i found this lil tid bit.
http://www.syty.net/phpBB2/viewtopic.php?t=32286&highlight=vortec+conversion
But anyway i just want to hear the pros and cons of using a thick gasket or gaskets to accomodate the vortecs to the lower manifold. And what is the pros and cons of machining the lower manifold by adding material.
Basically i just want to hear from waller, erue, js, or mike lee or somebody who does these conversions and could sell me on it.
If i buy a converted intake is it going to just bolt on and redrill the heads or am i still going to run into other problems like the oil pump drive not ingaging bc it would sit too high. Wouldn't both solutions raise the manifold and create the same problems? I would think as long as the 2x gaskets seal they would seal and would be a much cheaper alternative and would save a syty lower intake manifold.
Double gasket gives you about a 1/8" max sealing surface at the top of the port.
You also can't come close to port matching.
Looking for vacuum leaks and flusteration.
Gasket or welded, you still need to redrill heads so that is a wash.
There is a reason you have several choices for welding intakes, it works and works right. Double gasket is left over from when vortecs were first being used, not something used much if any on new conversions.
Any of the people on list providing the service do excellent work and very similar construction.
ItsMyTy
Life is beter at 25 PSI
don't double gasket
you're just asking for coolant and other leaks.
i have a mike renz bulk buy modified intake and it bolts right up. no leaks. no problems with distributor. not much material to port match, though.
hamrhead
I used the double-gasket's three times, and all three times I was leaking oil out of the engine, or anti-freeze into the engine, or both. :eek: Regardless of how well we tried to seal them up.
I decided to spend the money and get the lower welded up - problem solved!
Maxtor
I have an aluminum spacer with a regular gasket on the top and bottom of the spacer - never had a problem. I wouldn't go this route if starting from scratch, though, since so many people weld them now and do a great job.
If you decide to not weld your intake I would strongly suggest using a metal spacer instead of stacking gaskets. I think McCoy has them.
If you do spacers, distributor or boss needs to be modified. FYI.
I don't think McCoy doesn't double gasket anymore (could be wrong).
MikeRenz
not stock
ItsMyTy said:
don't double gasket
i can still get these done if you want. $425 to weld the lower, and $75 to drill/tap heads.
93ty475
Re: Pros/Cons To Using Double Gaskets For Vortecs
why does the search feature suck? i think we're all lucky to even have this board....it's even free...the search feature works for me...there was a time that it did suck though...but its does what its supposed to now....like the saying goes, garbage in garbage out...
tbauer03
TRBOBOX
i agree but there can be way to much info returned and it sucks to sort through it all. The filters can often filter out the info you want and unless you can remember some exact phrase from a previous post that you are looking for it can be hard to find. IMO we need a few more good articles in the vault for quick reffereces.
