cloneman315
ok i just got my 52 kit now what should ido for ijectors do i need new ones?also what other things do i need to know about this install how mutch boost through a stock motor is safe with the 52?
E-RUE said:dont listen to these guys..... bunch of nOObs.
as soon as you figure out where the turbo is located, just use the channel locks to remove the bolts, and stick the new one on. put some quick drying liquid nails where it bolts together so it wont leak. also squirt some oil into the impeller to "prime" the turbo before you start the truck for the first time.
after you get done, grab the distributor with both hands and turn the cap as hard as you can until it turns about an inch in the clockwise direction. dont worrie about loosening that bolt, thats how wusies do it.
you wont have to change anything else. should run 10's
e
