NJ93TY
I did a search but could not find anything. I am in the process of installing a PTE-52 turbo on my truck. Well I got the turbo with no fittings or adapters so I had to get a fitting for the feed line witch is OK now and the factory oil return line would not work. I got a oil return line from RPM and hooked it up to the turbo. OK so thats now good. Now the PTE wastegate does not fit because the oil return line is in the way. Also I am goign to run the RPM air to air intercooler so I have the turbo clocked facing downward and the wastegate will not line up properly to the flap in the 3" DP. I hope this makes sense to someone and maybe they can help me before I blow up my truck. I can get some pics maybe tomm if that helps. Thanks in advance.
