Pte 63 ?! ---
alwayscode390
pppssssshhhhhtttttttttttt
I am going to use this turbo on my new build.
ARE THEY ALL CALLED THE "BIG SHAFT" or is that a special version?! ---
* Who is a good SY porter, and how much does that run for both manifolds (open upper for 58mm tb) / vortec heads?
*Who sells headers for our trucks that will clear the turbo?
*It has a 3 to 4 adapter, what downpipe/wastegate should I use?
Thanks alot for your time .... I am hoping to get 450hp and mid 11's using a stroker, overbored new pistons, 1.6 rr's , 58mm t.b. , ported vortecs, 412, ultimate, headers, the pte63, meth injection, exhaust, intake, ect ---
alwayscode390
Re: Pte 63 ?! ---
I think I got an estimate from RPM, $2400 to port and polish the lower manifold and heads.....and install new valves/springs/ect. Anyone else have prices? Thats reasonable, but I was thinking it wouldnt be more than $2000 including upper manifold porting, considering you supply your own CORES ---
Flyin Ryan
hated cuz he drives fords
Re: Pte 63 ?! ---
Did you try campbell or anybody else in the vendor's section for pricing?? also you'll need a new downpipe for that turbo and it being oiled cooled doesn't mean you have reroute your coolent lines.. you just remove the stock coolent line to turbo and plug it.
alwayscode390
Re: Pte 63 ?! ---
I will try Campbell next. I wasnt sure if anyone besides RPM on this site was known for good porting work , thanks ---
Syclone0565
CustomMulticades.com
Re: Pte 63 ?! ---
The lower intake will not bolt up to vortec heads without modifing it. (Welding drilling etc) Porting the top out to fit the 58, if you have to , you can do yourself. Not hard, As for the turbo downpipe it depends on the hotside of the turbo. V-band flange or bolt on. Wastegate? Tial is a good one. You can get it here from the venders at a good price. Hope this helps. ;)
alwayscode390
Re: Pte 63 ?! ---
It has a 3 to 4 adaptor (what is that for?). The hot side is a .63 and it has a 3" inlet and 2" outlet. I heard an ATR downpipe will work? Thanks ---
Syclone0565
Re: Pte 63 ?! ---
3 to 4 adaptor is used when the turbo had a 3 bolt flange and you have to use it to bolt it to your stock 4 bolt exhaust flange.
ATR downpipe is a bolt on hot side and not a V-band. Yes ATR and I think there is another one that bolts right up. I am sure someone here will fill in the blanks.
skipztt
boost
Re: Pte 63 ?! ---
i would idmagine 3 to 4 adaptor is to bolt on the 63trim to a stock header. the 63 is probably a 4 Bolt flange. stock headers are 3 bolt. unless u buy aftermarket headers or have a fab shop make u some with a 4 bolt flange, u need the adaptor.
downpipe....depends on the style. v flange or does it bolt on? im not very fimilar with syty aftermarket parts so youll have to call around. i would guess the 63trim is setup for a v flange....cause they are the way to go and very common now. so u need a dp for a v flange if so.
hope this helps
jwaller
Evil Genius/SyTy Guru
Re: Pte 63 ?! ---
the adaptor is for using a buick turbo(atr on our stock manifolds or headers. that means you also need their downpipe. I change 1k for race port job on the heads 250 for porting the intake and 200 to mod the intake for the heads. 200 to drill the heads and about 650 for springs valves locks and retainers and studs. this should give you an idea of what I can do. also check my site on sprotmachines for pics of my work. pm me for more details.
Luke
Fish sticks SUCK !!!
Re: Pte 63 ?! ---
loubotzz77 said:
question guys im not gettin injector pulse on my ty the ty wont start and ideas
get your own thread dude :squint:
kwick6
Re: Pte 63 ?! ---
Yes, an ATR downpipe will work. I have a new one in the box if you want it. $500 + shipping.
I'd suggest getting a TiAL wastegate for the downpipe, such as this one....
http://www.detroitturbo.com/cart/product_info.php?products_id=139
If you have any other questions you can email or call the number in my sig. thanks.
