SeattleSy#1255
Category 5 Conservative
A bit confused:
I plan on running a custom chip with a PTE setup. Am I going to go ahead and use the stock boost selenoid? I'm confused because the only nipple off the turbo is connect to the only nipple off the wastegate.
I guess my question is using a chip for boost control on this setup, will it be like using the ultimate chip on a stock turbo/wg setup and if so are the vacuum lines routing similar?
