Raist103
Hey all I just installed my pte turbo and dp kit, and have some ?'s.
1. What do you do with the plug that went into the stock solenoid?
2. The wastegate rod goes as tight as you can then one back to set it first correct?
3. The kit came with a 3” high flow cat does anyone use this, or just run straight to the muffler? (I had no cat with the stock set up just a 3” cat-back)
Now a ? about the ultimate chip.
My button stopped working to change settings, could this be a wire problem, like a ground or power wire came off of the back of the button? I did not want to open it up unless I had some idea as to what it could be.
Thanks
Don
Thanks
Don
