pte turbo clearance issues
#2875
built, not bought
i must say i am disappointed with my pte 60 kit. the solenoid and wg arm both hit my fender which pissed me off because i mounted the turbo before i put in the engine.
well i fixed that and now the DP is laying on top of the frame.
this is after i ground on the AC bracket for about a half an hour to make IT fit.
anyone else have problems like this?
SeattleSy#1255
Category 5 Conservative
Re: pte turbo clearance issues
you just have to reclock the turbo, and do everything slow...it can be a PITA but it all fits without clearence, not by much, but it does fit.
i did mine with motor already in.
#2875
built, not bought
thanks but how will that make the DP fit? the exh turb housing is bolted onto the manifold so it can't be moved.
MAITAI1993
DON'T MAKE ME SLAP YOU.
nightmare :rant:
samehere its a bolt on kit they say :fist: :tdown: BULLSHIT....
SeattleSy#1255
that true...some people have problems when motor mounts are toast and motor has shifted...Not sure what to tell ya...the pte dp can be turned and adjusted a bit as it uses clamps, but other than that, from what i have seen, some people have problems some dont...
can be a big prob if it slaps against the frame and knock sensor picks it up and kills power all day long.
#2875
built, not bought
have solids that may be why. but it needs to move a half inch off of the frame at least so i'm thinking quality control at precision is garbage.
cloneman315
i had to heat mine and roll it in a lil so it didnt hit and then wrapped it,make sure it dosent hit or u will get false knock
Raist103
mine fit fine with room to spare before and after solid mounts. just got to put it in after the motor is in. takes maybe 2-3 hrs tops with installing the turbo and all lines.
blk97ta
do you still have the factory dp bracket ? my ty didn't have it and it had an atr dp and it was very very close ! so when i did the engine in the sy it had the bracket so i used it and it pulled the dp 2-3" off the frame .
E-Rue
iv never seen a truck that used the PTE kit with a 44-60 turbo that had the stock intercooler not fit, and require clearancing. unless you are rotating the compressor housing, or have something different about your truck it will fit without clearancing anything. the downpipe is a little snug, but it always fits with a little twisting of the joints.
e
#2875
built, not bought
e
well guess what? you have now. mine did not fit out of the box and the only thing not stock that would have made any difference is solid motor mounts which i bought from you.
mods were made to my fender well (BFH), AC bracket, and i still don't know what the hell i am going to do about the DP but i have rotated it in every direction as far as it will go and it won't fit without bending that section of pipe.
93ty475
Only thing I can think of is you might have to adjust the JS pads on the frame to clearance that DP off the frame....If thats too much trouble then just figure out where you need to cut the downpipe so you can rotate it to fit your truck, then have it rewelded....This isn't going to happen by itself....you have to make it happen....If I lived by you, I would do it for you....As far as your compressor not clearing your a/c bracket, personally, I would toss the blame on the PAS shitty quality control on our stock exhaust manifolds before I would the PTE syty exhaust housing....Nobody said this was going to be easy....I have found nothing to be easy about these trucks, especially working on "stock" ones.....good luck
ghettosled
SYTY SUPERSTORE
Believe it or not the PTE quality control on their downpipes is pretty good. Some trucks seem to have less clearance then others, but with a TO4E compressor cover it should clear the A/C no problem. when the bolts are loose it will contact when you spin it, but if they are just barely loose it should glide by the bracket. As for the downpipe, sounds like your motor mounts may also need adjustment.
Loeryder
I agree PTE prolly has better quality and standards than GM/PAS did when assembling our trucks.
As with intercoolers, turbos, coilovers, sway bars, whatever... You are going to have variances from truck to truck and you just gotta deal with them and get on with life or you'll be miserable forever.
