PTE Turbo Install questions
BillC
Howdy,
Has anyone installed a PTE turbo/downpipe/cat setup on their Typhoon? Which size turbo did you get (TE44, PT51, PT52, etc.)? How hard was it to install? Did everything bolt up, or was custom fabrication required? Did PTE's cat mount up to the stock/aftermarket exhaust system (if aftermarket, which system?), or did you have to make a custom cat-to-muffler pipe?
Finally, after all was said and done, were you happy with their setup? Did you notice any difference? If you were to do it again, what would you do differently?
Thanks,
Bill
SyTyJedi
Jedi Council
Everything is designed to be a complete bolt on for the most part. IIRC - you will need an aftermarket cold air kit, and need to block off your coolant lines, but that should be about it.
Do a search for PTE on this site. Look in lounge, tech talk, and how to mod and repair. Should be some more info there.
Here are some pics:
Lots of SyTy'ers seem to be happy with the results of their kit.
Of course, you'll need a chip to go with it, and the 50# 3Bar ultimate is the only way to go. It's from STG Racing, available thru AR Autosports. STG knows what they are doing, and know how to tune a truck properly.
smeagol
Bill's doing his own chipping at this point, and may be able to help out guys with similar builds, once his is done.
Stout short block
L35s worked up
ATR .430 lift cam
50s
Last I heard he's getting a PTE 52
He already has good results with his current calibration.
BillC
SyTyJedi:
I know that everything is _supposed_ to be a bolt-on. However, I haven't read anything from anyone who has actually done the installation about how well or easy the actual installation went.
I've already searched the bulletin board, looking for PTE installation posts. Other than a few "I like it" and "This should work" posts, there is NOTHING about the actual installation process.
I have also seen the pictures of the install on Opie's truck. In fact, I saw, first hand, the install on Opie's truck at the Nats in 2000. Unfortunately, his truck is the prototype, and doesn't necessarily represent the currently-shipping kit.
All I'm looking for is feedback from anyone who has actually done the install, or at least, witnessed the install first-hand. I'm aware of all the theory and "should fits"s and "probably will work"s. The problem is that this board is sorely lacking real-world feedback on this topic.
denny
Iinstalled the PT51 with pte cat, it bolt right up to my atr exhaust. You'll need a 3' 90 degree rubber elbow for the intake, also my oil return line did not bolt up right. I had to re-bend and twist it, still brace against my lower raditor hose. The down pipe is close to the frame but it dosen't touch. Performace wise I am kinda disappointed, I ran better with stock turbo.
Denny
92 ty nyc
fastsuv
Installed the PTE with the 52. Some types of problems. Had to bent oil return line a little, Downpipe is really close to frame. Other than that, the installation went really well. All the parts were included in the kit for blocking off the coolant lines, and installing everything. The only piece that was missing when I got it was the intake elbow. Performance was pretty good. It all depends on the chip and the tuning.
SyTyJedi
Jedi Council
No doubt...it seems like the list of people that ordered them was a mile long...and now nobody has it... :sad: :sad: :sad:
4C FED
Absolutum Dominium
I have it.
Wish I could say how well it works, I've just got to finish a lot of little things before it cranks over.
As for ease of installation, it is easy to access the 4 bolts that hold the exh. housing to the turbo collector.
I'm running a braided steel line for the oil drain, the flange on the stock drain was to small.
I actually have taken my turbo off and on several times to fit several things and it isn't as difficult to do as the stock setup.
Let me know if you have any more specific ?'s and I'll ry to answer them for ya.
