PTE +wastegate rod +thread size
bezerk
does anybody know the thread size of the wastegate rod coming with the PTE turbokits?
i want to run lower boost, but can't get it lower than 18PSI...this rod is to short:rotf:
nightdiver
Re: PTE +wastegate rod +thread size
You dont want anything less than 18 psi :)
With your bottom end id say 20 psi base boost is fine. Just kidding...........Do you want 15 psi for daily use and 18-20 for the weekend ?
bezerk
i want to get 15PSI (which makes it fast already).
waiting on a new chip, and some different size rockers...
+ that i don't have much faith in this engine anymore..
but i atleast have 50PSI at idle on 10w60 ;) opperating temp.
nightdiver
but i atleast have 50PSI at idle on 10w60 opperating temp.
Rene i found my oil pump pick up (that was welded) down in the oil pan. When the pick up screen was out i broke two lifters from over reving. The small safety wire that keeps the internals in their place got sucked from the oil pump and f**ked up the gears and bended the oil pump shaft a little bit.
This situation gave me 10 psi less, that it was nothing (HV+ HP pump). Then the pump gears started eating the housing that droped the oil pressure. I found the little wire in the oil gallery right after the main .
I ordered bearings and rings to fix it.The saft is good. Im also goind with a custom hydro cam.
I know , i know, its my luck :dunno:
I made my own rod for the PTE setup with a piece of metal and two nuts. I can't remember the size, but wanna say it was metric. I bought a little piece of metal from a hardware store about 1/2 inch wide and 3 inches long, and bent a 90 on one end to sit between the two nuts on the actuator. When you want to increase or decrease boost, you just loosen the nuts and turn one way or the other....no need to remove the stupid rod off the swing valve.
bezerk
i did exaclty the same....since i couldn't find the right size.
the weird thing is that i can't seem to get my boost lower...even is i take the rod off of the swinger, the boost will climb up really slow and at 4k rpm. i get still get around 18psi of boost..
if i make the rod shorter and attach it to the swinger.. i get around 15 PSI, and than the boost is starting to climb up again to 18PSI at higher RPM.
can it be that the wastegate isn't effiecent enought?
it's a PTE setup. and never heard about anything like this before..
bezerk
what's the name of the boat we are floating on?
bad luck is around us
Rene, since changing from a 63e with Ptrim exhaust to the 67GTQ with Q trim exhaust... I'm noticing the same thing. I think the turbine is flowing better and therefore harder to control the speed. I was thinking about porting the hole, but there isn't much left covered by the puck. I'll go search the TurboBuicks board to see how much material is needed to maintain decent spool.
bezerk
the PTE wastgates are quite large..around 30MM i think.
funny that this subject never came up before.
SY2932
Administrator
Nope, S.A.E. 1/4" X 28 tpi to be exact.
