pte67 t4 to t3?
JuStBlAzIN
OK I have came accross a little problem. I have a pte67 with a t4 exhaust housing. I believe the exhaust port is a solid 3" exit and uses a v-band clamp to the DP and the exhaust port. (i think thats what the clamp is called). The turbo is set up for an external waste gate. I live in california and I have smog up laws my A$$. So I want to keep it looking stockish. Can I convert the PTE67 that I have to the proper t3 exhaust housing and convert it over to an internal waste gate? Also what DP would i use?
If so what parts can I use?
If Not what DP can I use that has the external housing?
thanks for your help.
Fred
blk00z28
Forced to by choice
Re: pte67 t4 to t3?
Find out what trim your exhause housing is and call up pte. They can get you what your looking for I'm sure. It might not cost that much. They might be able to tell you what trim you have too.
You can try talking to mike lee(rpm) or Scott(Detroit turbo) and see if they can help you too.
Too keep this turbo you'll need to do something to make it bolt onto the stock manifolds first. A t4 flange is bigger then a t3(stock). But aside from that you'll have to run the piping, flange and buy a external wg.
If you get a regular internal wg housing with a t3 you'll need a pte 4 bolt style dp. I can't remember who offered those on here. But seeing pte started selling turbos for our app again might check them first.
Hard to say which way will be cheaper/easier..
Windedv6
Ty n 10s
Re: pte67 t4 to t3?
A PTE syty exhaust housing and the PTE or RPM DP. You will need the internal wastegate actuater.
John
