Pittman
I pulled the motor this weekend. I found little (some big) peices of metal everywhere. Couldnt figure out what caused it. Finaly realized that I have three valves that where all missing the inner spring. The springs had shattered causing metal to go everywhere. Every bearing surface and cylinder wall show signs of where the metal had been.
in other words 100% write off on that one.
I checked the remaining cyl head which was still on the motor and had the same problem with one valve. I checked lift and push rod geometery and everthing is good.
I have McCoy stg 3 heads
Crane gold race self aligning rocker 1.6
comp cams lifters
comp cams p rods
comp cams H5 gring cam .500 and .510
I have a new motor already in the works. Am I safe with this vavle train WTF I cant figure out what/why this happened
comp cams lifters
comp cams p rods
