let me say first every fing stud brock except for one. it was a nightmare the turbo and manifold had to come out together. Once i finally got everything apart out of the truck i carefully examine the turbo. I notice two things
1. A couple slightly bent fins on the intake side.
2. The wastegate hole is welded shut
The flapper is till in there attached to the wastegate rod and functions properly but there is a puck welded in the hole to bleed boost! This baffles me as this shit came apart hard as hell, i would have swore after i chisled nuts off and heated the studs with a torch(still didnt come out) that this thing was never taken apart before.
On all my datamaster runs i held a consistant 14.6psi and only spiked when cruising and downshifting. my passenger mani was cracked pretty bad so maybe thats all the boost i could build. Looking back on it i guess i should have realized it as when you were under significant load it would build as much as boost as you wanted.
sorry for my rant
sorry for my rant
