Codfish
Is there a special tool ? or a what size is the bolt on the side of the oil pan that connects to the turbo (I think its a return line)...
Big bolt larger than a 19mm
Thanx in advance
Wayne
FYI I am following these directions
Re: Front Diff trouble
To remove the oil pan: Remove the steering relay rod from both the pittman arm and the idler arm. Remove all 4 mounting bolts from the front diff. You do not have to disconnect the half-shafts. Remove front drive-shaft. You will be able to push all this stuff forward enough to remove the pan.
You also must remove both motor mount through-bolts, and raise engine until bellhousing contacts the tunnel. Block it in this position. (I used my cherry-picker).
Sounds nuts, but this works. I've done it.
Dave
http://www.syty.net/forums/showpost.php?p=587758&postcount=2
Thanx in advance
Wayne
Dave
