pushrods
redline7500
n/a 4.3 11-1 compression
i have a n/a 4.3 that keeps bending push rods, are the push rods in sy/ty motors thicker/stronger, if so where can i buy some
ed hess
race or get outta the way
Re: pushrods
comp sells the same ones in chrome moly.
when i had the 412 cam i used the regular ones form comp.
i bent 2. the guy i bought them from had sent me a set that had a couple bent ones also. changed to the cm ones no more bending.... go figure....
ed
sytyguy
Moderated User
I sell Manley 1 pc hardened pushrods for our trucks for $99 set. Waller and many others have been using these pushrods in high HP builds for many years without any problems. FWIW, Manley makes most of the aftermarket pushrods for the likes of Comp, Crane, etc....
HTHs
Hood
Loeryder
Michael,
When swapping pushrods do you just use the stock lengths or do you measure for new length after swapping heads to say L35s?
My plan is to run L35s with the 1.6 Crane golds, so i guess my question woudl be can I run the stock length>?
I'll give you a call to order the rest of the stuff I need to swap my heads here soon.
sytyguy
Moderated User
Stock length is 7.200", but you can go up or down safely .050 without much adjustment. L35s require no longer/shorter pushrod than stock, and there should be no need for a Louis tool or custom pushrods when using stockish GM iron heads AFAIK.
It's always a good idea to use a pushrod checker, but for what your doing (a proven and common swap), then I would just slap it together with stock length pushrods (I did). If something is way outta whack, then check for a collapsed lifter, misaligned rocker, etc....but you should have no problem.
HTHs
Hood
ed hess
guess someone outta mention, a little prussian blue on valve stem tip and you want to see the rocker makes contact in the middle 3rd.
if you see that the geometry should be correct.
ed
redline7500
where can i buy these cause im eating threw stock push rods(525 lift) like nothing, i know the rods i need are shorter than normal, but i can use the stock roller cam push rods in the 4.3.
