ed hess
race or get outta the way
Having done it i now recommend against relocating the knock sensor.
A dfi tuner looked at it in front of the lower intake and told me to put it back. prior to this i hadnt ever seen a single degree of kr on dm.
I finally hit the motor in a few spots to make sure dm could see it and it had.
Since the motor is new now 200 miles on it with no known false knock,
I think this is quite credible. Besides since the tuner wants it moved (tuners are like gods, Ya hear that Nolan and Brian?) you do what they say!!!
SO i moved it back to the oem spot last nite while waiting for harry to show up. Also tested launching with it in the new spot. I actually found a spot between 3200 adn 3300 rpm whan building boost up to like 12 pounds where i get a 2-3 degrees of kr that goes away at 3400 while still holding the brakes. Im a boost launch maniac here
Anyway then i go out and do the same driving tests an nail it in the same spot i always use to test boost and kr. An upward hill on ramp to the highway. Creates nice load. I saw a count of 300 doing this. Still not enough to loose timing but even so. Understand that dm didnt pick this up with the sensor in the moved location!!!
I have to beleive this proves that mounting the knock sensor to anyplace on the lower intake is going to be comprominsing the sensor picking up the engine harmonics of detonation.
I now beleive the tradeoff of false knock from a torq converter or other component isnt worth the risk of relocating the knock sensor in order to protect your money and labor on a newly built motor or an old one. better to find the real cause and fix it.
Otherwise its like using a kennebell chip.
ed
this might help future searches:
moving knock sensor
relocating knock sensor
knock sensor move
sensor move
ed
moving knock sensor
knock sensor move
sensor move
