I have a set of 33lbs injectors that were removed from a Ty, and i would like to know if the stock Sy/Ty injecors are a peak and hold type or the saturated circuit type.
Also if i understand this correctly, if your stock injectors are a Low Imp design, say 2.0 Ohms then you can install injectors that are low or high resistance and they will work no problems, but if you have a factory high Imp injector than you have to go with a high imp replacement becasuse the Low Imp injecotor will damage the injector driver??
Am i understanding this correctly? Im currently building a 2.2 Turbo engine fo rmy daily driver cavalier, and the factory injectors are a 2.0 OHM set up, and i was wanting to find out if i could use the 33lb Sy/Ty injectors in it that way i can get it running and not have to buy new injectors, theses ones i have are very low mile and in great shape. They spec out at 16 OHM, but i know some other guys that have built turbo cavy engines like what im doing and have used the ford red top injectors, which are like 14-16OHM resistance, with no problems and they are a 30lbs injector.
If somebody could answer these uestions i would be greatly appreciated.
Thanks
Thanks
