Question and idea for downpipe insulation?
Tophatjimmy
Syclone FNG
I searched and didn't find anything relevant so:
I had an idea, maybe a stupid one but since wrapping the DP in header wrap seems to be widely frowned on since it eventually destroys the metal, what if a section of thermal material, kind of like the type used in the old uppper IC blanket GP, let's say 36" or 40" x 10" was used as a one piece loose fitting downpipe wrap. With either velcro or maybe stainless steel buttons to keep it fastened?
That way, the heat is still kept away from the engine bay somewhat, but there is still air between the DP and the wrap to allow expansion/contraction of the metal and at least some air movement.
Here's the best visual I can think of. Remember the old BMX bikes that had the nylon wrapped foam bar pad on them so you didn't rack your nuts on it so hard? :rotf:
Kind of like that except no foam pad and made of heat insulation material.
I dunno, just a thought....
Re: Question and idea for downpipe insulation?
my :2cents: , and it's prolly worth less that that is; it depends on what you're trying to protect. Starter? Plug wire? Seems to me it would simpler, easier, to protect them than cover the DP but again just my :2cents:
It's just a six
Super Member
If you can fab or aquire metal material like from a cat converter shield, weld short "L" tabs on the downpipe so you can attach the metal material "shield" it will have an air gap.
That would be nice. ;)
