question for all the elec oriented guys...
BigBadSmoosh
Where do you all get your electronic components?
online stores?
retailers?
I have to do a senior design project, and Im basically just going to take the output from a GM obd I ecm (plug under the dash) use a Pic microcontroller to alter the signal and display error codes on a pretty looking 20 x 4 LCD screen.
I know i know, it sounds simple, but i find it challenging considering im supposed to do it from scratch..
instead of displaying the "service engine soon light" I want my little project to display what the actual problem is in plan old english.. so ill take the output from the ecm relate it to a description of the problem and display it on the lcd..
any suggestions from anyone?
Thanks!
Re: question for all the elec oriented guys...
In Newton, MA their is an electronic store call DIY electronics, it has best retail selection of electronic equipement in the area. It can be seen from the 128, its exit 19 (near route 9 which is exit 20)
BigBadSmoosh
im really familar with DIY, ive been goin there for a few years now.. great place.. kinda pricey..
thanks though..
:D
Are your thinking of grounding pin B on the diagnostic connector, to transmit the data to the check engine light? Have you thought about decoding the data stream on pin E, which has all the raw diagnostic data. The error codes are their. At a later point, you could add some usefully stuff like Knock Retard, Knock Counts, Etc that you would actually use.
ed hess
race or get outta the way
hey if your going to do the LATER part of what he just said:
Figure out the knowck retard part and then that gizmo your makin can be sold to all of us here to have a working knock warning led!
then you can get paid for your schoolwork efforts besides.
That is the american way.... i mean if you can make a profit, do it!..... :D
ed
BigBadSmoosh
I am trying to do the later part..
no pin b at all, all pin e..
Im planning on using it to display the error codes in the english language.. say error code 13 comes up, instead of flashing the little light (which it will do anyway) the lcd will display "Oxygen sensor malfunction"
then whomever is driving will have a general Idea about what the actual problem is, and not get ripped of by a mechanic.. The knock sensor thing is strickly sy/ty stuff, which I could probably add in, if i can only figure out the overall schematic and remeber assembly language again.
thanks for the help.
BigBadSmoosh
thank you myclone..
so anyone else have any input as to my idea..
I could get it to display all the info from the ecm on the lcd.. it would probably just be text and then a number.. but I might be able to make it look decent..
any suggestions or help is much appriciated.
sytydvr
hey Smaug the place to buy electronic components is all electronics located in Los Angeles. they have a website www.allcorp.com . I majored in electronics and one of my projects was to build a power supply well put it this way people that bought all there components at radio shack spent upwards in the $80.. I spent no more than 25$. I believe they have a free shipping promotion if im not mistaken.
let me know if that helps u out or anything else pm me
Joe
sy#682
ty#2351
