Question for external WG and manual boost control users
myclone
Ive got a external WG mounted on the stock crossover and a "bleeder" type regulator (very nice SS made by Swagelock).
I cant, for the life of me get it to regulate boost hardly at all. So.... Which side of the WG is vented to atmosphere via the regulator/needle valve? Ive tried the regulator on the top and bottom of the WG and I either get 9psi max (base spring pressure in the WG) or a max of 20psi not matter where I adjust the reg. Id like to run 22-24psi and maybe get this thing to run a 12.00.
This is prolly simple but for the life of me I cant get it to work.
TIA
myclone
Brian,
Thanks for the link but it no worky... Went to that links home page and did a search. Found several subjects in the archives but you gotta down load em.. I tried but it locks my system up each time..
Any suggestions?
TIA
smeagol
That is the system I've used on several external gates now. Best mechanical control available.
Find out what your base boost is as well, run a line straight to the side port without any bleeders/regulators in line, no lines to the top. You want your base boost to be within 6psi of your target boost (IDEALLY). The further away your target boost is from your base boost, the more inaccurate it will be. Some high dollar electronic controllers may be more forgiving, but i've found this to be the case with mechanical/regulator type control.
myclone
THANKS!!
Oh, wait a min.. I had it hooked up like that also and got a max of 20psi.. Hmmm, I'll try it again and see what happens as I mighta did something wrong the first time..
BG,
Thanks for the info.. Base boost is 9psi. I kinda noticed what youre talking about as once I start turning the boost up it doesnt rise as quickly after ~16psi. Low boost (16psi) it rockets straight to 16psi. Higher boost (20psi) it takes a few moments to reach it.
On datamaster at 16psi the measured boost graph rockets from 0 to 16psi. As I go higher the boost rise rate seems to slow down some. Looks like a "curve" or half of a sign wave rather than half a "square wave" . That make sense?
Its raining now anyway and the neighbors are prolly tired of me "whistling" up and down the road. Gonna call it quits for now before someone calls the cops. :D
myclone
Ughh. Couldnt sleep as this is bothering me...
BG,
Would switching to a stronger spring in the WG help? Ive got a 9 pounder in there now but AR has a 15 pounder available. Will having the 9 pound spring in there only allow me to run a max of 20psi no matter how the bleeder/regulator is configured?
The WG is a Innovative "Pro Gate" btw... Dunno if that helps ya any..
TIA for all the help.
smeagol
Slow spool, spikes/creep are the problems with going way higher than a base boost spring. In your app, shooting for 20psi control, a 13-15psi base spring would work, cuz I assume you want to run 15psi on 93 octane, then up it for race gas.
What happens is instead of the spring opening being a fast transition, it starts cracking early (if base boost is 9psi, it may start opening at 13psi when using a regulator, and fully open at 20psi..). With a tight, higher base boost spring, that crack pressure is higher. Exhaust pressure stays high, turbo speed stays high.
nightdiver
I got a kenne bell external WG and changed the spring with one that gives me 15 psi base boost.....so i never ever lost in a road race :D
myclone
Cool. Looks like the spring needs to be heavier as running 15psi on 93 oct and upping the boost with race gas is what Im doing.
Thanks a bunch!!!
nightdiver
Use the spring but be carefull cause i dont know what exhaust back pressure you have (inside the crossover)
I mean if you have a 64mm P tream wheel with 0,84 turbine ar your boost pressure will be very close to the spings rate, but if you have a small wheel with a small turbine the exhaust back pressure inside the crossover will push the spring to open =lower boost than expected
hamrhead
If you don't mind me asking, where did you get that replacement spring? I believe my base boost is around 13psi now, which is how I purchased it from KB.
TIA
nightdiver
I got it from a shop that makes them. Very good price and sst
But since yours is so close to your target just put a spacer 2-3 mm thick :wink:
SYO237
SyTy Registry
myclone...
im currently waiting for my WG to come in from AR, same setup as you...should be here soon hopefully
to much to ask if you could post up some pics of the install if possible? would like to see what went into it and this topic with the above info from greeny im sure will help alot when i goto do my install...
trying to save some of the headache and try not to get stuck in the same situation your in :p
thanks!
myclone
SYO237 said:
myclone...
thanks!
Wish I had some pics of my set up but I didnt think to take any when I put the WG on. There is a pic of a WG mounted on the stock cross over on ARs site. Thats what I went by to position mine. I'll see if I can dig it up and post it for you.
I might be fighting a bag regulator as this thing has got a mind of its own. I hook the WG up like in the link above and boost gets WAY outta hand at only 1/3 throttle. Ive turned the lines every which way but loose and it still wont work. I either get 9psi (base boost), 20 psi max, or 24+psi (I let out once it swings up to ~23.5psi). Im outta race gas and am gonna take a break from it and think about it. Gotta be something thats screwin me....
myclone
Here ya go.. (hope this works..) I stole em off AR's site (hope thats not illegal or something :eek: ). They are in the menu to the left on the site under exhaust/headers.
http://www.arautosports.com/xover3.jpg
http://www.arautosports.com/xover2.jpg
http://www.arautosports.com/xover4.jpg
http://www.arautosports.com/xover1.jpg
To position it I took the front bumper off along with the lower IC. I mounted the WG to the flange he sends with it then held it up on the X over. I use a felt tip marker to make reference marks on the X over where the WG looked like it needed to go. I pulled the X over off and tack welded the flange onto it. Then I put the x over back on along with the WG. Remounted the lower IC to check clearance. I had to tweek it just a little as there is no room to spare between the WG and lower IC housing.
Once I had everything in the proper place I pulled it all back apart again and did the final welding on the WG flange. Used a hole saw to cut the opening in the X over and dressed it with a die grinder (WEAR SAFETY GLASSES!!). Just reinstalled everything and plumbed the WG's hoses before I put the lower IC back on.
That might be more info than you wanted but once I get on a roll my keyboard tends to get away from me.. :wink: :D
HTH.
smeagol
I've had the problem you are talking about with the regulator. Make sure you are using the correct ports on the regulator. Most have 3 openings. One is for a gauge, other two are in/out. I believe it is important which way it goes. I usually put some air through the regulator on the bench, and slowly tighten it. You should hear the air flow through the regulator being slowed down and finally stopped as you are turning. Some regulators I tried didn't even seem to do this for me. The ones that worked well worked just as I said above.
Regulator completely open, no regulation of air, will give HIGH boost in the previously posted diagram.
Regulator completely closed, no airflow through at all, will give BASE boost when used in that diagram.
Somewhere in between = your control of boost ;)
myclone
Thanks BG.. I tested the reg on the bench before I tried it to verify exactly what youre talking about. It worked just like you say. Once I put it on the truck, however, it seems to act either all the way closed or wide open in just about every way I configure it except for the 20psi configuration. Dunno whats up with that. Thats why Im starting to think the reg is poss bad.
It is a "4 port" reg that I blocked off two of the unused ports and just use the "in" and "out". The "in" is connected to the comp side of the turbo and "out" is connected to the WG. The reg is also "vented" as in the bled off pressure is bled out via a separate port thats not accessable unless you take it apart.
Im gonna try a diff one as soon as I get some more race gas. I hit 20+ psi on 93 once and bout crapped my shorts. It was only for a split second but scarey none the less.
Thanks a bunch for the help so far
