question for you guys using the ult chip
wntasyorty
for you guy that have ran your trucks at the track what settings do you use on a basiclly stock syclone,my truck has 9/11 converter,atr cat back,fpr,ultimate 10 chip,255 lph fuel pump,and that is about it except the dequick lower heat exchanger,and tranny cooler.i run around with the setting in t-1 16 with no knock,i am going to the track soon and want to know the safest settings i can run now keep in mind i will ad 100 octane to my 93 to make a higher octane.also do you guys leave the truck in od or just drive?will it finish the quarter mile in drive?i know theses are dumb questions so please be patient,sorry i can't spell
SeattleSy#1255
Category 5 Conservative
Re: question for you guys using the ult chip
t2 or t3 20psi...stock turbo realy runs out of eff. after that.
assuming you are monitoring knock of course.
SY2932
Administrator
I run T2 20 psi for my runs with nine gallons of 93 octane plus three gallons of xylene (paint thinner 117 octane plus 93 octane = 99 octane blend). Race in "D" with TCC locked up via a switch. Unlock after going through the traps and shift into "OD" to keep from annihilating the overrun clutches in the trans. Run 30 psi in all four tires too. My mods are here. The highest timing program and boost that you can run safely will depend on the state of tune that your truck is in. Keep detonation in check or else you will put connecting rods through the oil pan regardless of the setting :( ...
93 TY 2185
I would run the tank down as far as I could with 93. Put 5 gallons of 110 in at the track. Run on T2-20 sometimes T3-20 if I was not seeing any knock. On the way home I would top off with a full tank of 93. Now I just fill my Alky tank.:cool:
wntasyorty
ok,so you guys are saying a stock waste gate will hold up to 20 psi?also what is this thing with a tranny switch,how does it work and can i use it with my 9-11 converter?thanxs for the answers guys
If its running 100% it should be able to run 20 psi and one of the higher timing programs. I would slowly increase the boost/timing (to make sure nothing bad is happening)
As for OD, if your truck runs right, you should need to do the 3rd to OD shift. Starting in D and do the 3-4 shift around 4500rpm or so.
wntasyorty
i think it is a lock up,because i can feel it in od when i get up to speed,my truck seems to be funning fine no knock at 16 on 93 pump gas,i am trying to get a serial port to usb connection so i can run my turbo link on the truck but i am having no luck on finding the wright connector,heck i even bought a new laptop and none of them come with the serial port.any help on that matter will be greatly appreciated,thanks allen
wntasyorty
well i didnt get to the track cause it rain on thrusday,but i did put 5 gallons of 110 and 5 gallons of 93 then i drove it around for about 20 min making good and sure the fuel was mixed well{i know i am kind or a tart when it comes to some stuff}then i switched it to t-2 18 and what a change,the truck came alive,there is only a little knock on the gear changes but other than that it has none,i was so pleased i drove the truck around for 2 hours tonight with a grin that i couldn't wipe off with ajax.now all i need is a new 60 turbo kit air to air and a fast system,oh i am so going to blow this thing up.lol
Mad Mike
SYCOSIS
Do you have data master or diacom? It's the only way to be sure. I ran both a stock typhoon and my syclone with bolts on's on the t3-20 setting.
wntasyorty
i have turbo link v4 but i need a older lap top because it wont link up with my new lap top
wntasyorty
well i got to run it last night at the local 1/8 mile track,
reaction-5.57
60 foot-1.74
mph-83
et-8.4
my settings were t-2 20 on the ultimate and no knock,what do you guys think?is this good for a syclone or just about average?
Honestly, I would have expected better Et's
When my Sy runs 12.9 I have 8.2 1/8 mile time, 83 MPH equate to about 103mph trap, when I lock the converter in 2nd gear. With 1.75 you getting good respect 60's time (mine are in the 1.8's because of tires)
I have similar mods (no 9/11, but I have ATR aux IC and 1.6 RR). I do have a bunch of KR issues and I run T1-16 or 17, so my truck is no benchmark.
If you run a switch to the first and last connection of top row of the ALDL, it will lock the torque converter, it depends on the truck, but you probably want to do it atleast in 3rd gear, I basic engage mine part way through 2nd gear, after I collect myself from violent launch and possible correction if it spins on the 1-2 shift.
I see about 1.5-2mph in the 1/4 mile MPH with locking up a stock converter. With a bigger converter, it maybe more beneficial.
