Question for you tuning guys
QUICK STORM
B.A.M.F. BMW Tech
well, i'll be dropping my new motor in with all the goodies in my BUILD SHEET (see sig.) and i wanted to know roughly what type of timing i should run and any other things that i should do/worry/fix while i'm tearing everything out. but my main question is about timing. TIA:tup:
Black Knight
I Glow Therefore I am
Re: Question for you tuning guys
Wouldnt you set it at zero, just to start to be safe, then hook up datamaster and go from there???
P.S. Dont forget to unhook your wire, its under the pass. side dash!!! :tup:
gjp
another post whore
just slam it in and get that thing running.
QUICK STORM
B.A.M.F. BMW Tech
i know, but i'm just trying to get a baseline idea of what to do, these are vortec heads so i can a little more advance
nallj92
you just set it normally and adjust with the computer tune, dont mess with mechanical advance
QUICK STORM
B.A.M.F. BMW Tech
you mean with phils chip, so i should set it to 0* btdc, thanks. just tring to think out loud about all the stuff that needs to be taken care of before i slap it in
nallj92
if his chip is for your setup, cam heads turbo injectors, you should be fine, ideally a custom tune would be the way to go but phils chips seem close other than a custom tune.
QUICK STORM
B.A.M.F. BMW Tech
yep chips is setup for all of the above
ghettosled
SYTY SUPERSTORE
all you are trying to do is sync up the timing. Set it to zero and the chip will raise or lower your timing based on manifold pressure vs. RPM.
QUICK STORM
B.A.M.F. BMW Tech
thanks mike, just getting real anxious. i haven't driven the truck in 10months:oops:
