Question on filling Intercooler
Bruce
I apologize if this is a silly question - I searched the forums and couldn't find the answer.
When filling or refilling the IC radiator, the shop manual suggests disconnecting the IC Pump, turning the ingition to on and crossing the wires to turn the pump on so that the antifreeze will circulate and you can fill it up.
Won't I get the same effect by running the engine with the IC Cap off?
Thanks, Bruce
Sy769
Re: Question on filling Intercooler
Thanks, Bruce
I have no idea what you are refferring to about crossing wires.
Ground the yellow wire on the IC relay permanently. It needs to be done anyway. That way with the key on the pump runs. Otherwise the stock ECM control allows heat soak to occur before the pump even comes on.
SY2932
Administrator
To top off the IC with coolant, take a paper clip and jumper the "A" and "B" terminals of the ALDL port under the steering wheel. The ports that you will want to jumper are the ones in the upper right corner and the one immediately to the left on the top. BTW, this is also how you pull diagonistic codes without a code reader... Do this with the ignition in the "ON" postion but do not start the truck.
If you don't see the coolant circulating around when you take the cap off, check your fuse in the weather pack connector behind the alternator as it might be blown. If the fuse is good, time for a new IC pump from Ron Gregory here: http://www.autoperformanceengineering.com/ When I bought my truck back in 98 the fuse was blown and the IC pump was dead.
FWIW with the stock chip, the IC pump won't turn on until the coolant reaches 215 degrees. That's why you won't see the coolant circulating until things get good and hot. I have the ultimate chip in my truck which turns the pump on as soon as the coolant exceeds 60 degrees. Wiring your IC pump to run continuously is your best bet if you intend to remain with the stock chip. How to here: http://www.sytyarchives.com/howto/viewarticle.php?article_name=ic_pump_hotwire.php&dir=engine HTH's
Mike Campbell
