Question on ver. 8 ultimate chip
havin-fun
NWSTP
Instructions say that the 3-bar programs are tuned for a stactic fuel pressure of ~50 psi at idle. What do I need, less than 50 psi or 50 psi, I believe stock sy's have 45 psi :eek:
Sy769
or you can energize the fuel pump by applying 12 volts to the test lead located just under the relays on the firewall. Should be a empty female connector on a gray wire
50 psi is a starting point. Changes will initially affect fueling across the board. As long as you are in closed loop you can vary it somewhat as the computer can adjust somewhat.Closed loop adjustments in a syty computer are kind of crude so if you start to get driveability problems you have about reached the limit either up or down.
Play around with the pressure until you get the WOT tuning close. Just make small changes.
Some people have made their best times with the fuel pressure either to low or high for driveability but optimized for WOT. At that point you really need to make some calibration changes IMO
