Question(s) about the 20G.
Methuselah
Can a stock wastegate actuator be modified to work with a 20G?
How much does a replacement actuator run for a 20G and where can I buy one?
Thanks.
________
Toys Vid
leroy
I think the problem has more to do with the wastegate port than the actuator. The port should probably be enlarged as much as possible. An actuator with a stiffer spring may help. Hahn Racecraft used to sell them. Not sure about the cost.
Jim
Maxtor
The mounting bracket is different, but the length should be the same. You could probably modify the bracket on the actuator to fit.
Hahn Racecraft used to sell actuators - you may check with them at their website.
Methuselah
http://www.hahnracecraft.com
I don't see it listed on their website but it does seem likely they have an extra to sell.
This post is mostly for the board member I sold the 20G to. I completely forgot that it didnt have an actuator because I have an external wastegate on the crossover and it was not an issue. When I tried to put the stock actuator on I realized there was a problem.
Hopefully I can save face.
Thanks.
________
Glass weed pipe
Methuselah
I'll direct the board member to whom I sold the turbo to your post. I included a stock actuator so hopefully he can modify it instead.
Thanks.
________
Creampie Mature
