First off....... yes i did search first however i could not find assured info on the following questions
same concept only i'm converting my v8 s10 from 2wd to awd, and have picked up some parts.
or anyone having converted from 2wd to awd, problems you've run into...etc
ok so...
did anyone going v8 in their sy/ty have to move the engine back far enough for radiator clearance that they had to have a front drive shaft custom made?
are bravada torsion bars the same as sy/ty? i am told yes.....?
is front prop shaft from bravada the same as sy/ty? I am told yes....?
does it make a difference on the year of frame or anything 82-93?
is the cross member for the torsion bars to go into the same as 4x4 s10? i am told no...?
is my 94 4x4 blazer trans a 700r4 or 4l60e? they changed to 4l60e in 93 for suburban. i am told yes....?
what is involved in me getting the 4l60e wired in to work properly, and where exactly does the trans wiring come from? wiring for 4l60e and also regular wiring for vss from 700r4?
as soon as i get more info i will start a build thread just in case anyone is interested. i have calculated that to do this with an already Small blocked truck i will spend no more than $1k at most. got the transfer and front diff, 175 for both.
picked up a bravada front diff and transfer case, along with trans.
ok so...
