jklein68
I'm going to be installing and degreeing a CAM for the first time and wanted to run some thoughts/questions by you guys.
I have a Comp Cams custom grind that is supposed to be installed straight up. The CAM card indicates @ .050 INT: 1- BTDC
1. Does 1- mean it should be retarded 1 degree at top dead center?
2. If that's the case hopefully it should be at 1- after checking the CAM straight up. Otherwise I will need to adjust.
Also, I have not bought a degree kit yet. I see that the "pro" kits come with a much larger degree wheel than the "standard" kits. Should I be concerned with buying a smaller degree wheel say 9" or will that be fine?
Last one I promise... I also have the opportunity to degree the cam with the heads off. Any pros/cons to degreeing with the heads off vs. on?
Thanks!
Thanks!
