ticlone
Esss in the house!
I'm trying to make sure I have a solid understanding on this. If you have a manual boost controller and you are adjusting boost, how do you know if the boost is being increased or decrease? How do you tell by what increments you are increasing or decreasing?
Also do you shorten or lengthen the stock waste rod to make the turbo spool up faster? And when using DM can you tell if you have made the wastegate too tight?
