Ok first question is the fuel pump schematic. Is it specific to SyTy's or is it like a "normal" S10? Ie: Ecm controls the coil on the fuel pump prime relay and then fused ECM/ fuel pump power comes across the oil pressure switch? Also wondering what exactly takes place in an over boost situation. What does the ecm shut down at 15 lbs boost?
Thanks,
Thanks,
