Quick LC 1 question
TYTILIDIE
METH HEAD
Instead of using the flat blade pins, can I just splice and solder in so that I can re-use my stock o2 at anytime just incase?
TYTILIDIE
METH HEAD
Re: Quick LC 1 question
Actually, if I hook up the yellow to the stock o2 wire, and then the brown to f14, do I HAVE TO run the LC-1 or can I run the stock o2 alone. Reason I ask is cause this is taking me forever and I have to drive the truck while Im installing this. SO I need to be able to dive when ever with out problems. So as long as the LC1 isnt powered, will having the wiring (minus power wires) hooked up to the ECM be a problem?
cvcsmkr
i dont understand what your asking completely?
is this for temp hook up or permanetly?
i only power up my lc1 when i need it.
but it will not send a signal to the ecu, unless you power the lc1.
my chip is set for open loop, so it isnt looking at the ecu for any data.
