The DIY for pump diagnosis indicates that there is an IC pump fuse in a black fuse holder behind the alternator. I am envisioning an inline bayonet fuse holder, but don't see anything like that. Am I not seeing the forest for the trees here? Sorry for the dumb question, but my IC pump appears to be dead.
BTW I can hear the relay work when I ground the yellow wire so logically if the fuse feeds the relay, then I suppose the fuse is OK. However, if the fuse protects the circuit to the stock IC pump, then maybe its just the fuse......or a dead IC pump.
Any clues for the fuse holder will be appreciated greatly.
Thanks
Jeff
Thanks
Jeff
