Quick Ultimate Question
0966Sy
Code what?
Do the newest versions of the stock heads/cam Ultimate 50# cals still have the electric fan control through the IC pump relay to turn on at 160F?
Need to upgrade my old version just checking to make sure my fans will still turn on with the chip.
Thanks
smeagol
The stock heads/cam 50# chip is on version 4. It has the fan control via the IC pump relay control, I believe it is set for 160-170 degree F.
Tooky
Serious about performance
Brian, what kind of times are people generally running with the following 4 chips?
Ultimate 50# stock heads & stock cam
Ultimate 50# L35 heads & Comp cam
Ultimate 50# Vortec heads & Comp cam
Ultimate stock injector
If you prefer to not answer here can you please email me privately? Thanks.
