Re: Race Results
The track was worse than my local roads as I could not drive it through the tires spinning. At least on my local paved county road I can stay in it and allow it to pull through the slippage areas.
The best run I had was on my lowest boost setting 10-12 lbs and rolling out on the foot brake with no burn out. (My burnouts sucked anyways). We tried a few passes at higher boost 14, 16, and 18lbs. On these run I tried running part throddle until I got farther down the track, but still blew the tires when I opened it up. On the 18lb runs I was spinning the tires in third.
Considering all this...a bad track is better than no track (most times.), Plus nothing broke. That's always a good day!
The truck ran cool (172*) all day and my intake temps dropped during the passes. It seems to like the E-85. With the tunning settleing in it's time to work on the suspension and the driver.
John
