Radiator
BMFB
Not to scale
alright, so i had a bearing go out, which threw all kinds of fun shrapnil into my oil, and therefore, into my oil cooler in my radiator. Now, ive been told its impossible to flush out, and not worth the risk, so im going to, but heres my cheap side coming out...I also drive a 91 blazer, and i was looking at the radiator, and it looks to have an oil cooler in it, thats not being used, just blocked off by plasitc things, i took on off and looked inside and it looks to be functional. I was just wondering if anyone knew if they were swappable, would save be a hundredish bucks for the build.
Thanks!
1madgumby
Re: Radiator
Yes, should be the same Rad..
Thanks!
mattw
Re: Radiator
Sorry Mike but +1 for the seperate oil cooler. IMO the radiator should be seperate from the oil cooler and seperate from the tranny cooler. I hate these combined setups...
warmpancakes
Re: Radiator
the rad mounted "cooler" isnt much of a cooler its more of a temp leveler as it can only "cool" to the coolant temp
mattw
Re: Radiator
Why? Because they fit and function so well?
The stock stuff does fit and function well I totally agree with that. My problem with it is that if the tranny fails you need a new rad, engine fails, you need a new rad...
-Matt
warmpancakes
Re: Radiator
-Matt
if the tranny fails you flush the cooler, takes about 10 minutes
