Raising the Dead
Ty 1450
30psi on 93 oct (boom)
My Ty has been sitting for a year, i just started bringing her back to life. I replaced the water pump and changed the oil twice to make myself happy. No water leaks and she's idling great, to finish off the day i wanted to break boost in the drive to hear my blow off valve and end my day with a smile. Of coarse I'm not smiling, when i was break boosting i could hear the turbo spool up but i couldn't get over 0 psi. I check all the fittings for the A/A everything looks tight, any suggestions. Also replaced the belt.
Quickstop [UK]
Combating adversyty.
Re: Raising the Dead
What gauge are you reading off? Have you got an aftermarket one?
Vac lines old/perished? Is your BOV working right or dumping pressure?
Stock turbo/wastegate? Wg stuck open?
Ty 1450
I have a aftermarket gauge, and by boost controller has one also. I thought about the BOV while laying in bed last night. I'll check it tonight to see if it's bypassing. Thanks for the tips
Ty 1450
BOV is working correctly, had a friend check the bov while break boosting.
