Ramcharger fan going out?
Throws
Anyone ever had a Ramcharger fan go out? Did you get a new set of motors, or did you just replace the assembly? I found out my fans gave up when I was heading home and smelled an "off" plasticy smell... not like wiring burning.... but different enough that I got worried (ICM went out on me last week and I ended up getting towed). I noticed my temps weren't changing, but it was cool enough out I figured that I was better off taking it easy.
I got home and checked out the engine compartment, and noticed a smell (same as I had smelled in cabin). I turned the car on and noticed that the fans lost their "low" speed ability, and on "hi" they wobbled and made noise. So... the fan motors are shot...no biggie.
Looks like they see this over on turbobuicks.com.... looks like most fan setups lose a motor every year or so. Is this something that people here have seen before?
I'm planning on going to the pick and pull, but thought I'd get opinions/experiences from here.
-P
Neelsonwheels
Re: Ramcharger fan going out?
I installed a dual fan setup I bought at Jegg's. They are a perfect fit. They are the same unit that RPM sells. They are on/off only no high low. They work great for me. some folks will prolly tell you to go back to the mechanical fan because it better but that is up to you.
Good luck. Oh by the way. I changed them out due to my Ramcharger fans melting down.
Throws
Got a part number? I think I'm going to keep the RC setup for a bit... but I'd like an eventual alternative. ;)
-P
Throws
The fans are from a dodge intrepid
Should be easy enough for replacement fans then... is this something that's pretty common for failure with these? I love the hi/lo, I love that it's on a switch... juuuuuust not the burning out.
-P
Flyin Ryan
hated cuz he drives fords
I've had one on my syclone since 09 wired to two relays fed by the ic pump circuit without any problems granted it hardly ever gets moved... also have had the same done except with a caspers harness in my daily driven mustang for the last two years without a problem and I believe they are out of a 2000 intrepid.
warmpancakes
Dennis (roaming Gnome) has spare motors, I might have one left at home but and LH car has the same fans
warmpancakes
nope the fans fail because they were scrapped by chgrysler because they didnt pass test, and ramchargers bought them
Flyin Ryan
I thought they stopped using the volvo fan in question because they had so many controller failures with them?
