Rating turbos in HP
I understand flow aspects of turbo chargers. But how can you rate a turbo charger with hp. Like for instance the gt35r is rated for 600hp. The 20G is rated for like 400hp. The 16g is rated for 350. I have seen setups with a 16g turbo make 400 crank hp. How can you rate a turbo by hp when there are a vast amount of applications it could be used on. I think CFM and lbs per minute is all I would be really worried about. How is the hp rating derived?
vortecfiero
Re: Rating turbos in HP
hp could be guesstimated based on
pressure ratio and flow and efficiency or density ratio and an average volumetric efficiency of about 85% at peak natural aspirated HP.
Matt
Not stock, but a modded 20g not sure on the specs made 593hp and 791ftlbs at 24 psi built by the boys at Campbell Automotive :tup:
