rattle at full boost
mildtowild
Custom Upholsterer
only when i am at full boost a get a metal on metal rattle. I have only had it a couple of days and have replaced the ic pipe (somehow he thoght electrial tape would hold boost) with a metal one. This would be my first guess of course but i doo have clearence between the pipe and turbo/IC. any other thoughts?
mildtowild
Custom Upholsterer
Re: rattle at full boost
also realted or not, I blew out chunks of either my Cat or muffler(i hope) so i would not doubt if it was pretty clogged.
pinellas50
New Guy
My first thought is detonation too. You need to keep out of boost until you figure it out or you very well may be blowing more than muffler pieces out of the tail pipe!
WyoSyclone
If electrical tape was holding your turbo to IC pipe together, I wouldn't doubt that your intercooler pump is NOT working.... high intake temps = detonation. Take the cap off and check for movement in the coolant.
You really need to get Datamaster so you can get a handle on boost/AFR's/timing... a fuel pressure gauge is also a good thing to have handy with these trucks.
mildtowild
Custom Upholsterer
So i pulled my battery and noticed that the vac line to the wg soliniod was off. I am no expert but i would venture a guess that no wg = to much boost.
